Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Reinforced Concrete Beam › Reply To: Reinforced Concrete Beam
agyaw1
Here I mentioned all the images of the model. Concrete is cracked in this situation, so the result doesn't match the theory. I saw your tutorial and inserted the command in the solution, but there wasn’t any change in the answer. Specifically, can you help me in which section I need to change or add a command to model a reinforced concrete beam? I am trying it in a beam model, but my actual structure is different. Thank you.
Ashok
