Ansys Learning Forum › Forums › Discuss Simulation › Fluids › DPM particle momentum transfer › Reply To: DPM particle momentum transfer
September 14, 2024 at 2:27 am
Zwernjayden
Ok thank you. I know collision works because if I turn off collision, no breakup occurs at all and the streams just clip right through eachother and hit the wall. Ill try the vof-dmp transition maybe
