Ansys Learning Forum Forums Discuss Simulation Photonics far field projection of gaussian beam Reply To: far field projection of gaussian beam
Guilin Sun
Not sure if your plot is near field or far field. Here is my test:
Above is the farfield, and below is the near field:
Please check if the Gaussian beam injection plane is large eough.
Since NA=0.1 is relatively small, you can use scalar Gaussian beam. Of course you can also use NA thin lens beam which is more accurate.
