Ansys Learning Forum Forums Discuss Simulation Fluids The following error occurred: The FLUENT application failed to initialize. Reply To: The following error occurred: The FLUENT application failed to initialize.
Federico
Check the Fluent solution transcript to get more details as to when this happened. If the solution fails at initialization, this would suggest there might be something wrong with the setup.
