Ansys Learning Forum Forums Installation and Licensing Ansys Products How to substitude the values of array B in A without using DO loop? Reply To: How to substitude the values of array B in A without using DO loop?
ashish.khemka
Hi Mehdi,
In APDL (ANSYS Parametric Design Language), you can substitute the entire value of one array into another without using a DO loop by using the *VOPER command. This command allows you to perform vector operations on entire arrays. Here’s how you can do it:
*VOPER, A, B, COPY
This command will copy all the values from array B into array A in one step, assuming both arrays have the same dimensions.
*VOPER (ansys.com)
Ashish Khemka
