Ansys Learning Forum › Forums › Discuss Simulation › Fluids › ROCKY particle impingement count › Reply To: ROCKY particle impingement count
Lucas Bertollo Baggio
Hello Kiran,
You can use two separate particle time selections: one for particles that adhere to the wall and another for those that collide with the wall and bounce off. This will allow you to track every particle that has interacted with both areas at its last timestep within the domain.
If you are familiar with UDFs, you can create a module using the Rocky Solver SDK to handle these calculations. Within this module, you can also incorporate the critical heat flux value.
best regards,
Lucas
