Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Force/Moment Reactions at Contact (Weld Seam Evaluation: nominal stress concept) › Reply To: Force/Moment Reactions at Contact (Weld Seam Evaluation: nominal stress concept)
georg.gruber
Hello, I'm back :-) Thanks for the APDL lines, I had to add one line in the beginning. Here my entire (working) snippet:
SET, last, last      ! Not working without this line
cmsel,s,FACE ! FACE is a named selection for the top flange face
esln                 ! It doesn't make any difference If I add or uncomment this line
spoint,,-350,330,19  ! x,y,z are the coordinates of the centroid
fsum                ! Compare with Mechanical
allsel
In the logs I get the result for fsum via APDL, at least exactly the same results as given by the Reaction Moments inside Mechanical. So Mechanical is apparently using the lines above. But, I still don't know where my problem is :-(
