Ansys Learning Forum › Forums › Discuss Simulation › Electronics › WARNING: Coupled simulation restarted due to out of sync coupling cont › Reply To: WARNING: Coupled simulation restarted due to out of sync coupling cont
alexia.carenini
Hi, i forgot to say that even if in the ICEPAK document the surface materials are correct, in the coupling that i obtain they are wrong (steel-->i think it is the default material), i think that the cause is the fact i use a maxwell design but in maxwell i can't decide the surface material, i have the material of the all component, there is no division between surface and body.
