Ansys Learning Forum Forums Discuss Simulation Fluids Rotating and mass flow inlet Reply To: Rotating and mass flow inlet
Hmm, not sure you need the DEFINE_EXECUTE_AT_END, but you will need to assign the wall bits in the SOURCE as not sure what is passed within the code.  An easier option may be to split some cells out near the wall & then just add the source into the smaller cell zone.
