Ansys Learning Forum Forums Discuss Simulation General Mechanical Create two material curves for biaxial analysis in APDL Reply To: Create two material curves for biaxial analysis in APDL
Sai Deogekar
You should be able to set TBOPT to UNITENSION (or UNIAXIAL if you have combines uniaxial tension and compression data) and to SHEAR or SSHEAR and add the two sets of experimental data. Have you tried this already?
TB (ansys.com)
4.2. Experimental Data (ansys.com)
