Ansys Learning Forum Forums Discuss Simulation General Mechanical Distance between two points in Static Structural Reply To: Distance between two points in Static Structural
kayla-anne.e.jack
Hello, thank you for your reply. Unfortunatly that post doesn't explain how to find the distance between the points before the load is applied. Is it possible to measure these points before running the simulation? I have created nodes at the min and max points, however I don't know how to measure the distance between the nodes.
