Ansys Learning Forum Forums Discuss Simulation General Mechanical How to include effects of gravity load in Modal Analysis Reply To: How to include effects of gravity load in Modal Analysis
erik.kostson
Hi
What you have (mass and gravity load) will cause a pre-stress (compressive load/stress will lower beam frequency for its bending modes) – see here for some theory details – the effect is called stress softening or stiffening (if tensile load /stress is applied to beam say)
https://innovationspace.ansys.com/courses/wp-content/uploads/sites/5/2020/10/Lesson4_ApplicationsOfLargeDeformation.pdf
This can be captured with a pre-stress modal – see here in our course for more details.
https://innovationspace.ansys.com/courses/courses/modal-analysis-in-ansys-mechanical/lessons/how-to-perform-prestressed-modal-analysis-lesson-2-2/
Also look through the rest of the courses (response spectrum)
https://innovationspace.ansys.com/product/modal-analysis-in-ansys-mechanical/
https://innovationspace.ansys.com/courses/courses/single-point-response-spectrum-analysis-using-ansys-mechanical/lessons/how-to-perform-response-spectrum-analysis-lesson-1/
Seacrh for more courses there.
You can perhaps combine results later (so add gravity with SRSS response spectrum results say) - look on solution combination.
All the best and good luck with your studies
Erik
