Ansys Learning Forum Forums Discuss Simulation General Mechanical Reinforced Concrete Beam Reply To: Reinforced Concrete Beam
erik.kostson
Hi
We do not have to use hex8 solid185, the default is hex20 solid186 which you use - I just showed it in my tutorial because it helps when models are large (less dof and nodes with hex8 solid185).
If you want to use it still see image 7 or slide 8 called slab for the settings (El. Order = Linear)
All the best
Erik
