Ansys Learning Forum Forums Discuss Simulation Photonics CHARGE: No change when Simulating Voltage-Dependent Transmission Reply To: CHARGE: No change when Simulating Voltage-Dependent Transmission
ph23resch01002
Hi Sir,
As you said, I have selected the sweep object to the attribute only, it seems like, the transmission amplitude changes very negligibly with respect to the applied voltage. That's why we are unable to see the difference. I have to check why it is changing only negligibly. If you can give any suggestions on this, it would be great.
Thank you,
Kind regards,
BharathyÂ
