Ansys Learning Forum Forums Discuss Simulation Fluids mach at inlet higher than at throat nozzle Reply To: mach at inlet higher than at throat nozzle
S.Shrestha-4
Hi! Area ratio is correct. Since it's meant to operate in vacuum, I put the ambient pressure at the outlet far from exit = 30 pa. Is there any other way to incorporate this? As that does not seem to work?
