Ansys Learning Forum Forums Discuss Simulation Fluids mach at inlet higher than at throat nozzle Reply To: mach at inlet higher than at throat nozzle
Essence
What Mach number are you expecting at the outlet? I suspect either the pressure ratio or the area ratio is incorrect.
