Ansys Learning Forum Forums Discuss Simulation General Mechanical Transient vs static analysis Reply To: Transient vs static analysis
Ashish Khemka
What is the duration of tranisent analysis, what is the maximum value of above function during the analysis? Also, check for large deflection effects - are they on in both the analysis (static and transient)?
It would be difficult to comment further without looking into the model. Ansys employees cannot look into the model. Do you have access to Ansys Support? If yes then you raise a support case.
Ashish Khemka
