Ansys Learning Forum Forums Discuss Simulation 3D Design GPU List for Ansys Discovery Explore Mode Reply To: GPU List for Ansys Discovery Explore Mode
Kin Chen
Hi Devendra,
I’ve retaken this test with Nvidia RTX 4090 and got the results below.
1. Test Model:
2. BCs:
3. Test Result_ Max. Fidelity:
4. Test Model_ Scale Down Model Size:
5. Test Result Scale Down Model Size:
As we can see from the above results, RTX 4090 still can’t solve the full model containing the 1-mm gap feature until scaling down the model size or extracting the region surrounding the 1-mm gap.
On the other hand, I followed your advice to utilize local fidelity in Explore mode to capture the 1-mm gap feature. While it resolved the full model containing the 1-mm gap, some results weren't satisfactory for review with GTX 1650 Ti but were sufficient for review with RTX 4090.
  6. Local Fidelity:
 7. Test Results with local fidelity with GTX 1650 Ti:
 8. Test Results with local fidelity with RTX 4090:
According to these test results, it’s clear that the higher-level GPU we use, the more resolution we can get whether utilizing the local fidelity or not. And that’s exactly what I’d like to know what is the smallest feature we can get with the GPU we use?
Is there any resource available like List of Compatible Discovery / Discovery Live graphics cards -GPU but in a version of 2024 R2 could provide for reference? It’s even better if there is information about the smallest feature of different levels of GPU.
Best Regards.
