Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Multi-stage simulation under cold forming using Transient Structural › Reply To: Multi-stage simulation under cold forming using Transient Structural
pierre.buchholz96
it took a while to simulate this, but it was cancelled with this error:
(I did it with minimal steps of 200 and a pinball radius of 10mm but not in static structure yet, I will try this now)
*** ERROR ***                           CP =   28162.141   TIME= 02:29:06
 An error has occurred in the Distributed Sparse Matrix Solver used by
 the PCG solver while saving the solver workspace data.  Error code =
 18.  Please send the data leading to this operation to your technical
 support provider, as this will allow ANSYS, Inc to improve the
 program.
 ERROR: Worker process(es) with rank(s) 2 have encountered a FATAL error.
 The information below was gathered from the file*.out output file(s).
 Please review the worker process output file(s) listed below for more
 details on this error.
 Worker Process Output File .\file2.out:
*** FATAL ***                           CP =   28081.828   TIME= 02:29:06
 MPI error code = 943788558 which translates to:
 Message truncated, error stack:
 PMPI_Allreduce(388)…………………….:
 MPI_Allreduce(sbuf=0000006D58DEB32C, rbuf=0000006D58DF3340, count=1,
 datatype=MPI_INT, op=MPI_MAX, comm=MPI_COMM_WORLD) failed
 PMPI_Allreduce(374)…………………….:
 MPIDI_Allreduce_intra_composition_beta(775).:
 MPIDI_NM_mpi_allreduce(134)……………..:
 MPIR_Allreduce_intra_auto(60)……………:
 MPIR_Allreduce_intra_recursive_doubling(175):
The simulation in the ‘Static Structural’ module worked! Thanks for the tip with the pinball
