Ansys Learning Forum Forums Discuss Simulation Fluids code won’t print all the temperature values Reply To: code won’t print all the temperature values
Federico
 When running Fluent in parallel, each compute node will handle a subset of the domain's mesh. Hence, try your UDF on a single CPU (serial) and see if it works. If it does, you will need to parallelize your UDFs. 7.3. Parallelizing Your Serial UDF (ansys.com)
