Ansys Learning Forum Forums Discuss Simulation General Mechanical coupled field harmonic analysis with pretension Reply To: coupled field harmonic analysis with pretension
ErKo
Hi
Ansys empl., are not allowed to download any external files.
Set load control to keep all disp. as zero (see image below):
To try that it is OK then – just apply zero voltages everywhere so no electric excitation (all zero) in the coupled harmonic analysis, and then all results should be zero.
If you getting nonzero results with the above recomend., then:
Finally,I have tried it out on myside (similar case as you show), and it works all good in 2024 R2 (I would suggest to download 2024 R2 – latest version).
All the best
Erik
