Rahul
Most of the time these values are case dependent. try changing it and see what works for your case.
Initially you could try using URF = 0.8 and decrease further if needed.
for scale factor start with smaller values ( e.g.1e-3 ) and then increase. coefficient-based method has been shown to be more robust than the volume based method so it is recommended.
