Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › ANSYS ACT script for getting node ID of maximum results. › Reply To: ANSYS ACT script for getting node ID of maximum results.
September 9, 2024 at 6:28 am
Hi
You can find similar scripts in the discuss asnsys forum which you can change and tailor as needed to do what you need.
https://discuss.ansys.com/discussion/1761/insert-normal-stress-get-maximum-and-find-which-nodes-have-the-max-stress-value
https://discuss.ansys.com/discussion/3542/write-max-vm-stress-for-each-part-in-named-selection-to-file#latest
All the best
Erik
