Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Unexpected result in tensile test: Bending effect due to Tensile load › Reply To: Unexpected result in tensile test: Bending effect due to Tensile load
September 7, 2024 at 8:45 pm
Thank you for the reply.
I tried to make the top and bottom of equal thickness by adjusting the infill percentage and this is what I got…(screenshot attached below)
Although the bending significantly reduced in the structure compared to the previous one. But if you look carefully this time, a slight amount of upward bending is still present in the structure.
Can you please help or suggest how to shift the origin of the infill?
