Ansys Learning Forum › Forums › Discuss Simulation › Fluids › fluid viscous stress calculation in fluent › Reply To: fluid viscous stress calculation in fluent
September 6, 2024 at 12:00 pm
Hello,Â
High Viscous Stress Near Walls: At the walls of the nozzle, the fluid velocity is close to zero (no-slip condition), while the fluid in the center moves much faster. This velocity difference causes viscous stress between the fluid layers, which tends to slow the fluid down.
Low Viscous Stress in the Core: Away from the walls, where the velocity is more uniform, viscous stress is much lower.
do you mean to calculate the overall viscous stress for the nozzle? Or are you specifically interested in any viscous stresses at the exit?
