Ansys Learning Forum Forums Discuss Simulation General Mechanical Can I create bonded/rough contact between two surface with slight gap in between Reply To: Can I create bonded/rough contact between two surface with slight gap in between
Sushant
Thanks Nanda, setting 'Penetration Tolerance Adjustment' to 0.1mm solved my problem and I am able to simulate Bonded contact succefully.
