Ansys Learning Forum Forums Discuss Simulation Photonics The two modes overlap the integral Reply To: The two modes overlap the integral
anna.wirth-singh
Are you calculating the overlap via the script command? In this case, one possible cause for that error message is simply using the incorrect name to reference the desired mode. To call the mode that is selected in your screenshot, use "global_mode1" rather than "d-card 2".
If this is not the cause of your error, please reply back to let me know and I will look into it further.
Best,
Anna
