Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Ansys 2 way FSI Issue › Reply To: Ansys 2 way FSI Issue
September 5, 2024 at 1:54 pm
Rahul
Max Iterations/Time Step ‐ Interpreted in SyC as Fluent iterations per Coupling Iteration.
Use fewer iterations than a normal transient case
‐ Rough guide is:
• ~5 iterations for cases with initial fluid solution
• ~10 iterations for cases without initial solution
Aim to converge the Fluent by end of Coupling Step.
