Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Ansys 2 way FSI Issue › Reply To: Ansys 2 way FSI Issue
September 5, 2024 at 12:27 pm
Hi Rahul,
I did not find this oiptzion in Ansys Fluent: "monitor force/heat flux, etc with report definitions in Fluent. Do not use too many Fluent iterations per coupling step, this will help you to improve the solution time."
Could you send me the SS of where exactly I can find it? Also, how many Fluent iterations per coupling step is recommened or how can I find the optimised value?
In addition, I have an additional doubt which I have attached below:
Thank you!!!
Ashish
