Ansys Learning Forum Forums Discuss Simulation Fluids Function choose in Function Calculators Reply To: Function choose in Function Calculators
Essence
Since the flow is incompressible, no energy equation solved (simple flow without reversed flow), you know that velocity = (mass flow rate)/(constant density*cross section area). You can determine mass flow rate, density and cross section area. You can then verify with which of the four fits to your application.
