Ansys Learning Forum › Forums › Discuss Simulation › Electronics › I’m designing a dual stator synchronous generator. How can i fix this error? › Reply To: I’m designing a dual stator synchronous generator. How can i fix this error?
sojoseph
Source setup error, possible reasons are 1) The solved region is not singly connected. If any circle in the solved region can not be freely shrunk to a point, then solved region is not regarded as singly connected. 2) The master and slave boundaries are separated. For this case, “Zero Tangential H Field?boundary condition need to be assigned on one boundary connecting master and slave boundaries.
how can the above error be solved?
