Ansys Learning Forum Forums Discuss Simulation General Mechanical transient thermal result data shifts in workbench Reply To: transient thermal result data shifts in workbench
n2390n
Isee
The model will look like this when viewed from the side, width = 10um
and i wanna know surface temp. between no.4 & no.5
The current results confuse me, here's some pic of my result
at specific time, the highest temperature is about 32 degrees at the surface between no.4 & 5
and this is the path temp. data in the same surface
Here is the problem, why there's big temperature difference at the lower interface when the heat is conducted from top to bottom.
thx anyway
