Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Force/Moment Reactions at Contact (Weld Seam Evaluation: nominal stress concept) › Reply To: Force/Moment Reactions at Contact (Weld Seam Evaluation: nominal stress concept)
If it's worthwhile, APDL could be used as a check on the values in Mechanical. I think it's possible that a small error in the centroid location could create a large error in the moment. The APDL commands would be something like this:
cmsel,s,face ! face is a named selection for the top flange face
esln ! is the tube connected by contact? If so, this command will only select the tube elements and contact elements
spoint,,x,y,z ! x,y,z are the coordinates of the centroid
fsum ! Compare with Mechanical
allsel
