Ansys Learning Forum Forums Discuss Simulation Preprocessing Edit mesh on cross section of a specimen Reply To: Edit mesh on cross section of a specimen
Sampat Kumar
Hi Domenico,
1. Section plane is only used to see the cross-section view of the mesh body. It will not allow you to create the mesh on that particular section.
2. As I can see in the second image, the geometry is hollow. If you want to mesh the edge, apply the edge sizing there, and, similar to the face, also apply the face sizing or body sizing as per the requirement.
3. It’s not clear from the previous question what specific issue you’re facing. Is it a mesh problem or a geometry problem? If you believe the geometry is incorrect, please modify it in the CAD software you used.
Let me know if the updating geometry helps.
Best Regards,
sampat
