Ansys Learning Forum Forums Discuss Simulation Fluids Convergence issue with Non Equilibrium RPI Model Reply To: Convergence issue with Non Equilibrium RPI Model
Prashanth E
Hello:
The convergence difficulties with wall boiling models usually has to do with low y+ (with quenching correction used with it). Can you make the mesh coarser if that is the case..
