Ansys Learning Forum Forums Discuss Simulation General Mechanical Vertex size mesh constraint with sphere of influence is not working Reply To: Vertex size mesh constraint with sphere of influence is not working
neil.haddock
Thank you for the reply.  I tried a smaller mesh size but it's still not working.  Also, if that were the cause of the problem, wouldn't it be the same for 2D analysis mesh (I use a 1.27mm mesh size for all bodies in my 2D analysis and the program seems to have no problem generating the transitioning mesh).
