Ansys Learning Forum Forums Discuss Simulation General Mechanical Coupled Workbench Transient Thermal Analysis with LS-Dyna Structural Reply To: Coupled Workbench Transient Thermal Analysis with LS-Dyna Structural
Ram Gopisetti
Hi Emmanouil,
Currently, within LS-DYNA WB we do not offer native support to import the heat flux other than temperature using the following workflow
However, you can explore the *BOUNDARY_FLUX_SET to set the flux values as load curves in the LCID for every segment inferred by the element or perform the entire thermal step within LSDYNA WB and use dynain or multi-step analysis workflow to proceed with the next steps.
Cheers, Ram Â
