Ansys Learning Forum Forums Discuss Simulation Fluids Convective heat transfer simulation Reply To: Convective heat transfer simulation
Essence
Yes, you can do it in Fluent. Create seperate cell zones for solid and fluid and ensure the option of Participates in Radiation is turned ON in solid cell zone, in case you need radiation in solids. You can also add the heat source in the fluid and solid cell zones.
