Ansys Learning Forum Forums Discuss Simulation Photonics Error importing layout design from Cadence Virtuoso Reply To: Error importing layout design from Cadence Virtuoso
Niki Papachristou
Hi Jong,
Thank you for reaching out to us! I think this has to do with the layer map format and more spefically the file content. Are there 5 columns in the file or otherwise? If you see the last column as the Cadence layer indication, you can remove this column, and try it again.
Kind Regards,
Niki
