Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Convergence Issue in Custom Non-Linear Materials › Reply To: Convergence Issue in Custom Non-Linear Materials
September 1, 2024 at 9:02 pm
I suggest you delete all output requests in the Solution branch of the outline.
Under Analysis Settings, Nonlinear Controls, set the Displacement Convergence back to Program Controlled.
Please show all the Analysis Settings you have. Do you have Auto Time Stepping On? If not, turn it on. What do you have for Inital and Minimum Substeps? Try a value of 10 and 10. Do you have Large Deflection On? Turn it on.
Please show details of how you used material stress-strain data in Engineering Data.
