Ansys Learning Forum Forums Discuss Simulation General Mechanical Question about randomness of result Reply To: Question about randomness of result
peteroznewman
One way to smooth the contact pressure distribution is to change the default normal stiffness.
Ansys Contact Behaviours: Formulations - Mechead.com
Change Normal Stiffness to Factor and use a value of 0.1 or 0.01 instead of the default value of 1.0 and change Update Stiffness to Every Iteration.
Another thing you can do is use a finer mesh in the contact region. This is easily done using a Contact Mesh Sizing control.
Take the free course on Contact Mechanics.
