Ansys Learning Forum Forums Installation and Licensing Ansys Products Fluent: Heat Flux on Solid Fluid CHT Interface Reply To: Fluent: Heat Flux on Solid Fluid CHT Interface
gordon.howat
I understand re. export law. I'm UK based and can contact EDR Medeso for support but hoped this may be faster, I haven't used the forum before.
Perhaps I'm misinterpreting the terminology. I'm decoupling the wall/shadow pair as it seems to be the only way to force a specific value of heat flux from the solid into the liquid, no other reason.
Changing the wall/shadow from "Coupled" to "Heat Flux" in the GUI enables a flux to be specified.
If there's any other way, I'm happy to do it differently. My objective is to artificially force a pre-calculated heat flux between the solid/fluid, I dont mind how I get there, if in fact it is possible!
Thanks again.
