Ansys Learning Forum Forums Installation and Licensing Ansys Products Fluent: Heat Flux on Solid Fluid CHT Interface Reply To: Fluent: Heat Flux on Solid Fluid CHT Interface
We're very limited on what we can cover on here as the Forum is public and must comply with Export Law.
With what you propose I'd be VERY careful to ensure I knew where what heat was going and that both the fluxes & temperatures made sense. I'd also continue to question why you're modelling both parts in one simulation if they're decoupled in this way.
