Ansys Learning Forum Forums Installation and Licensing Ansys Products Fluent: Heat Flux on Solid Fluid CHT Interface Reply To: Fluent: Heat Flux on Solid Fluid CHT Interface
So not an interface, it's a wall & shadow pair. If you decouple (slit) the pair using a TUI command both become external to the domain. However, I'd then question why you want to model both parts in the same simulation.Â
