Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How current is defined in Litz wire for Winding excitation?? › Reply To: How current is defined in Litz wire for Winding excitation??
MirandaH
hello, the current in a Litz wire for coil terminal excitation with a winding structure is defined according to the stranded source conductor bodies, which are applicable to any magnetic field problem where the source of excitation comes from a coil. It's the total current through the cross section.
