Ansys Learning Forum Forums Discuss Simulation Fluids Problem with simulating mass transfer in a membrane-based system Reply To: Problem with simulating mass transfer in a membrane-based system
yassine20soumbati
Yeah I know they are a bit tricky, that is why I wanted to see what are you suggesting to do exactly or where to start at least. I will try to look for the older threads though. Thank you :)
