Ansys Learning Forum Forums Installation and Licensing Ansys Products LS-Dyna Beam elements outputs Reply To: LS-Dyna Beam elements outputs
Armin
Hi Fady,
Did you get a chance to follow the workflow provided in your earlier post: LS-Dyna beam stress and strain (ansys.com)
In short, set BEAMIP under DATABASE_EXTENT_BINARY card to a value greater than zero (depending on the number of integration points in your model), and then some of the beam results you’re looking for become available.
