Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Rotor is mounted on journal bearings. is cylindrical support be used in analysis › Reply To: Rotor is mounted on journal bearings. is cylindrical support be used in analysis
sudhakar917
I have carried out the analysis with cylindrical supports – the expansion is 90 microns.
The same analysis with journal bearing (with stiffness & damping properties ) gave 220 microns of expansion.
I am not able to comprehend the deviation in results.
Please clarify, which support is correct.
Sudhakara
