Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Gear tooth deformation due to rotational velocity › Reply To: Gear tooth deformation due to rotational velocity
Deepak
Cylindrical support can be used to represent bearing behavior in some cases, but for precise deformation and dynamic analysis, incorporating the specific stiffness and damping properties of journal bearings is recommended. These properties are crucial for accurately calculating the dynamic behavior of the system.
