Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Gear tooth deformation due to rotational velocity › Reply To: Gear tooth deformation due to rotational velocity
sudhakar917
Deepak,
I have used cylindrical support in the place of journal bearings. Is it correct to use?
or Do I need to use journal bearing stiffness and damping properties to get exact value of deformation?
Please clarify.
Thanks,
Sudhakara
